Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 - screen replacement - no auto-brightness - laggy screen
I replaced the screen on my iPhone 6 with the iFixit iPhone 6 LCD Screen and Digitizer Full Assembly. Since the replacement, my phone no longer auto-adjusts the screen brightness and the screen has become very laggy, sometimes causing the screen to freeze, sometimes opening things I didn't touch, and sometimes not recognizing my touch at all.
I took the phone back apart to make sure all connections were reseated properly, however the problem persists.
I tried to remove the front facing camera and ambient light sensor from my original screen in hopes of replacing that part of the replacement screen, but the ambient light sensor disconnected from its cable in the removal process, so that is a no go.
I never had either of these problems with the original screen. Is this happening because my replacement screen is faulty?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes the screen could be faulty for the random touching, no touching, and freezing. However, for the auto brightness that is dealing with the proximity sensor. Make sure the sensors are seated well into the screen. and look for any damage to the proximity sensor flex cable. If there is damaged you can get a replacement for $7-$15USD on Amazon. But the screen is a bad screen you need to return it and get a different one.
Was dit antwoord nuttig?
Voeg je antwoord toe
Emily Resner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 183
