Ga door naar hoofdinhoud
De Garmin Nuvi 65LM gps werd uitgebracht in 2014. Dit apparaat beschikt over een 6-inch scherm met dubbele oriëntatie, vooraf geïnstalleerde kaarten met gratis levenslange updates en miljoenen doorzoekbare nuttige plaatsen.
GPS stopped working after map update
My GPS stopped following and showing the rout, and giving directions
after I did a map update, 5.60 version, with "Garmin Express" software on
my Mac PC. How to troubleshoot the problem?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Are you Facing Garmin GPs is not working after the update? These types of errors showing due to technical faults and hardware malfunctions. We have to share some causes and Troubleshooting Steps to resolve these issues.
Causes of Garmin GPS Not Working after the Update:
1. Garmin GPS is Not working
2. Garmin Nuvi stopped working
3. Garmin Map Crashing
4. Touch Screen is Not Working
5. Garmin GPs Won’t Turn On
Fix Garmin Express Not Working After Update:
1. Click on the start menu button and go running window and also types ‘services. msc’ in the search field.
2. Click the Enter button.
3. After that, you will show the Garmin Core update service option and right-click on it.
4. Go to the account setting in which select the network service. Make sure that any password is filled from the provided field.
5. click on the ok button, until you can see the apply button that will save you all the changes made setting.
6. After that, right-click on the Garmin core updates service and then click on the stop button.
For More Solutions just click Here: https://bit.ly/3AoKcOC
In case you can face any difficulty in applying these steps and find any free Garmin Map updates you can directly contact a Garmin expert through Chats Support.
Was dit antwoord nuttig?
Voeg je antwoord toe
Gene Ras zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 718
