Ga door naar hoofdinhoud
Repair and disassembly guides for the Alcatel A50 budget smartphone. The Alcatel A50 was released in July 2017 and includes a 5.2-inch display.
20 Vragen Bekijk alle
Why is my sound not working?
I have a new Alcatel A50 and the sound keeps disappearing. I restart the device and the sound works just fine for a while but then suddenly stops working.. I have Bluetooth off, sounds on, do not disturb is off.. Help?
Is dit een goede vraag?
Score 2
1 Opmerking
This didn't work, either. I've had it just a little over a year, bought new. Also the alarm works but there's not even a setting for notifications! Wtf?!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @jimmybf ,
Try starting the phone in safe mode (same for all Alcatel models) and check if the sounds stays on OK.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one. you'll have to uninstall each downloaded app one by one and test the phone after each uninstall. Once the problem has stopped the last app uninstalled was the culprit.
Update (05/19/2018)
Hi @jimmybf ,
If it still fails in safe mode, try a factory restore (or hard reset).
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its' factory default condition
Perform a backup of the phone using the phone's backup feature before you do the hard reset.
Once it has been reset, check if the problem is still occurring. Give it some time if it takes a while to show up.
If it still happens, then you have a hardware problem.
As you said the phone is new, verify the purchase date of the phone to ensure that the manufacturer's warranty period is still valid. (Check the the manufacturer's warranty statement that came with the phone) It should also tell you what you have to do to make a claim for a manufacturer's warranty repair or replacement.
If the phone works OK after the reset, (again give it time to show if it's going to), then restore the phone from the backup that you made earlier, using the phone's restore feature.
When the backup restore has been completed check that the phone still works OK. If so then the reset has fixed the problem.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
This is happening before I had any apps installed. I'll give safe mode a try. I thought I solved the issue by turning off bluetooth but it happened again
door
OPTIONS
Permalink
History
Mine showed a line through the speaker icon on top bar along with battery, alarm set, time, ect. I held down on/off button and on bottom showed three possible settings. On the right side it showed the icon for speaker w/o the line. I clicked on this and problem was corrected. Sound is back on.
door
1 Opmerking:
I have Alcatel TCL ION cell phone sound intermittently goes out as well. I'm my case it's not an app it happens more then not. It's Alcatel phone. There's no fix till Alcatel patches. Sucks have to have Bluetooth device for speaker all the time. There is no fix yet.
door
Voeg je antwoord toe
Jimmy B zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 42
Altijd: 12,914
