Ga door naar hoofdinhoud
Guides and repair information for Shark vacuums.
298 Vragen Bekijk alle
Why is this filter spinning around in my Shark vacuum?
Hi,
The filter spilled out of my canister when I was dumping out the dust cup and I put it back in. But now it spins wildly in the canister making the whole vacuum vibrate. It doesn't seem like it's sucking as much now and also making high-pitch squeaks due to air being forced.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here is a link to the ifixit Shark Vacuum guides.
Hopefully your model is listed (you didn't specify) as most guides show how to remove and reinstall the filters.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks, I'll check it out.
I have a Shark Apex Powered Lift-Away.
door
I figured it out. I had the filter in the wrong part of the dust cup housing.
Rookie mistake ;)
door
Voeg je antwoord toe
Robbo4473 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 122
