Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Vragen Bekijk alle
Board to Board Connector For I/O Board (Main MB Connector)
I am trying to find this connector thats on the board but I cannot figure out who manufacturers it or a part number. It is the I/O Board to Board connector on the main motherboard and the original I am trying to replace was damaged. Anyone know what it is or where I can get one preferably new.
Board to board connector I am trying to identify and replace
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Board connectors can be very difficult to source...in some cases they are only available in bulk directly to manufacturers. While I don;t know where this one can be found I'll make a few suggestions which may help out, if not you then others who will invariably find this question in the future.
  • This is considered a rectangular board-to-board connector. There are many manufacturers of these types of connectors including Panasonic, Molex, JAE etc.
  • Check out sources such as Digikey & Mouser and do a parametric search by pins, size, pitch etc...you may strike gold.
  • Do a search on Aliexpress by pcb model number and connector name (i.e. J2300)
  • Order donor boards. They usually have the CPU and RAM/NAND removed and a hole drilled in the center. For certain hard to source parts, this can be the only option.
Good luck with your search. If you find one, make sure to report back for the benefit of others. Maybe someone else like @mayer, @reecee or @tcrs_circuit who specialize in Mac's will have better info.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Nick your logic board is a 820-3787 and the connector in question is J9510 Board-to-Board Flex connector. It is listed as a 20590-032E-25
door
Thanks @oldturkey03, I hadn't gotten around to that part yet :>).
door
@refectio anytime Sir, anytime ;>)
door
Het nuttigste antwoord
Your going to have to pull it from a donor board. Use lots of flux, and heat the donor board from the bottom from directly below the connector. You will need a beefy hot air station like the Quick 861DW. To solder it, your going to put some leaded solder on the pads, wick it away, add new solder and flux, place the connector then bottom heat again on the patient board.
There is nothing easy about this. It is a real pain
Score 4
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 253
