Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Tried to fit new screen
Hi I'm hoping u can help me , I've replaced the screen etc on my sons 'phone and it came on at first but then had loads of lines and gradually no picture?
I have isoprolol if that will help ?
Which parts are a actually the lcd s?
Thank u xxx
Update (05/17/2018)
I've ordered another replacement screen any advice on which parts 2 be careful of or which parts are most delicate? Xx
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Fading with lines on the LCD is the signal not properly coming from the image control IC on the LCD assembly.
Very likely, either the flex, or the LCD itself is damaged. This could have come from the place you have purchased the parts from (manufacturer defect) or could have happened while fiddling with the part. This is very common for home repair, due to the tiny amound of oressure it takes to cause damage.
There is also a posibility of a loose connection, but it actually far less common than the part being internally damaged.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thank u very much for your reply. It was my first attempt at this so it's possible. If I order another have u any tips on where I went wrong or which bits to be careful of? Xx
door
Any tips on how not too damage a new one please ? Which parts are most delicate? X
door
the most delicate area are the flex cables of a new screen. never let them stretch. hold the screen at a 90% angle from the phone while handling the new screen, and never go beyond that. this will keep them from stretching.
While connecting a new screen, always make sure the connectors make a clicking noise as they go in, and dont let the connectors bend if you can avoid it.
door
Het nuttigste antwoord
it could be the connector isnt correctly attached, disconnect the lcd and reattach making sure they clip in properly. remember to disconnect the battery before any screen replacement otherwise you could damage the backlight circuit
Score 2
1 Opmerking:
Thank u very much ill try again and see how it goes thank u .
I can see the screen lighting up behind the silver plate if that helps? Xx
door
Are you talking about the horizontal / vertical line artifacts that appear on the screen?
Chances are it's from using a aftermarket iPhone 5s screen. To fix this issue you will need to either use a Aftermarket SE screen, Original 5S or SE screen.
Score 1
1 Opmerking:
The lines were horizontal and gradually faded to nothing . I was under the impression it was a genuine iphone SE screen replacement but I followed it step by step ? Xx
door
Voeg je antwoord toe
Debbie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 87
