Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
How to stop iOS update to the latest version notification?
Apple does really disturb me when my iPhone pops up notification to upgrade to the latest iOS. It said that iOS 11 is not so good to the elder devices, I use an iPhone 6 and it works good as for now, I do not get used to upgrade, apps or system. If there's any way that can stop iOS nagging me to update to the latest version? Thanks for any help.
Is dit een goede vraag?
Score 1
2 opmerkingen
That pop up isn't the iOS update pop up, it's the carrier settings update.
door
Doesn’t work. It deletes it but it comes back in a few days. Eventually it stops for maybe a month. But then comes back again, despite my automatic updates being supposedly disabled. I’ve had the slider to off for almost a year, and I’ve deleted update pushes form apple about 40 or 50 times. This is an old “fix” and is only temporary. I’ve deleted the iOS 12 update 4 times in the last week, alone, despite doing this “fix” last winter.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Trying to be careful as my answer was marked as spam. you can find the profile (Beta Profiles) Block Update for IOS online. Download the profile and follow instructions. I used it on iOS 14.2 and it removed the notification and blocked iOS 14.3 from downloading.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
I find the iOS update queries very disruptive as well however what you are showing us is a Carrier update, which I highly recommend you do. It will not affect or change your iOS.
Score 3
1 Opmerking:
You may not have read my question, the screenshot is just a screenshot, I've chenged to another screenshot which can show the problem, but it is an iOS 9.0 update notification, I got it online, just for reference. Do not be so aggressive. I appreciate your quick reply, thanks anyway!
door
This is the best way I can think of.
1. Open the Settings app and go to “General”
2. Choose “Storage & iCloud Usage”
3. Go to “Manage Storage”
4. Locate the iOS software update that is nagging you and tap on it
5. Tap on “Delete Update” and confirm that you want to delete the update*
This deletes the available iOS update which stops the iOS update from popping up every day, however, the moment you’re on a sustained wi-fi connection for a while the iOS update will download itself again automatically and start sending pop-ups to install it again. If this happens, just redo the steps.
You won’t lose the ability to install the iOS update, you can download it again yourself by going to Settings > Software Update, or just join wi-fi and leave the device unattended and it will download automatically without prompting.
I hope this helps!
Score 1
3 opmerkingen:
Than you, Leo, your answer seems promising, I'll try it out.
door
Keep me updated!
door
Really helpful, thank you!
door
Voeg je antwoord toe
Albert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 5,875
