Ga door naar hoofdinhoud
Rockchip Quad-Core RK3288C-processor, 11,6" 16:9 HD (1366x768), 16 GB eMMC, Geïntegreerde Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard-geheugen 2 GB / 4 GB
certain keys wont respond
Letters and numbers such as (8, i, k,) wont apear on the screen when I press on them , what do i do ?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Hi Salma Repole
Try following this step below to dismantle your keyboard
Asus Chromebook C201 toetsenbord vervangen
there is a lvds cable which is connected to the mainboard. Disconnect it carefully and clean up your keyboard.
Afbeelding
Use an eraser to rub on the LVDS cable connector of the keyboard module and reconnect it back.
Test your keyboard, one good link to test and spam the keys...
http://www.keyboardtester.com/
Launch It and test...
If all fails, consider getting a replacement keyboard module from ebay.
https://www.ebay.com/itm/New-Asus-Chrome...
Was dit antwoord nuttig?
Score 2
Hi,
Here are some possible fix -
  1. Update Windows
  2. Update Keyboard Drivers
  3. Install/Uninstall the keyboard drivers
  4. Plug and unplug the keyboard
  5. Try keyboardtester.org
Hope these steps will help you to make your keyboard working properly.
1. Check for Physical Issues:
  • Dust or Debris: Dirt or dust under the keys may cause them to not register. Try cleaning the keyboard.
    • Solution: Gently clean the keyboard using compressed air or a soft brush.
  • Sticky Keys: If something has spilled on the keyboard, certain keys might be stuck.
    • Solution: Clean the keyboard using a damp cloth with a small amount of rubbing alcohol, or consider removing the keycaps (if possible) to clean underneath.
2. Check Keyboard Settings:
  • Filter Keys (Windows): This feature sometimes ignores repeated or brief keystrokes.
    • Solution:
      1. Go to Settings > Ease of Access > Keyboard.
      2. Make sure "Filter Keys" is turned off.
  • Accessibility Settings (Mac):
    • Solution: Go to System Preferences > Accessibility > Keyboard, and ensure features like Slow Keys or Mouse Keys are disabled.
3. Test on Another Application:
  • Test Keyboard Input: Open a different app (e.g., Notepad, Word) to see if the issue persists.
    • If it works elsewhere, the issue could be specific to one app.
4. Try Another Keyboard:
  • Plug in another keyboard (USB or Bluetooth) to see if the issue still occurs. If it works, your keyboard may be malfunctioning.
5. Driver or Software Issue:
  • Update Keyboard Drivers:
    • On Windows: Go to Device Manager, expand Keyboards, right-click your keyboard, and select Update Driver.
  • Restart Your Computer: A restart may solve temporary software glitches.
6. Hardware Failure:
  • If none of the above work, the keyboard could be damaged and may need to be replaced.
7. Check with an Online Keyboard Tester:
  • Test Key Presses: Use an online keyboard tester to check if the keys are registering at all.
    • Solution: Go to a website like keyboard-tester.org and press the unresponsive keys. If the keys don't show up, it's likely a hardware issue with the keyboard.
Voeg je antwoord toe
Salma Repole zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 32
Altijd: 2,757
