My cameras battery area is corroded! how can I replace this?
the batteries were left in the the battery area and corroded. I was able to remove them but the area is badly corroded. Is there any way to repair this?
Is dit een goede vraag?
Keeping the camera upright so nothing drips inside of it, a mixture of water and baking soda will clean things up. Apply with multiple foam Q-tips to get up inside the battery compartment. Use high-strength (91% or higher) isopropyl alcohol on a foam Q-tip to clean out the baking soda mixture.
Was dit antwoord nuttig?
@snap2 as this is corrosion caused by the alkalinity of the battery I always use a water/vinegar mix and a cotton tip applicator to apply it. Use a toothbrush for larger, more corroded areas, like the battery compartment cover etc. In your case, I suggest that you actually dismantle the camera for a good cleaning. That way you can be assured not to get anything into the camera, which could cause other problems.
Generally to clean up corosial I use a bristle brush or qtips dipped in the highest concentration isopropyl alcohol I can find. Once done with that I would leave the camera to sit for a few hours to make sure any remaining liquid dries up and evaporates.
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 110
Altijd: 12,749
