engine keeps sputtering and backfiring when giving gas or under load
I have a briggs and Stratton 23 ohv engine on a john deere zero turn 425 mower. It ran perfectly last week. went to start it this week to mow and now it sputters, black smoke and backfires all when trying to give it gas. it will not run fast nor can I engage the blades as the load makes it do the same thing and cut off. I changed the plugs, cleaned the carb, checked the valves, the blades move freely. It starts up and will idle and run on the lowest throttle setting but it will not do anything else. As soon as I try to push the throttle to fast and engage the blades it goes crazy. I don't know what else to try.
Is dit een goede vraag?
1 Opmerking
is there water in the fuel perhaps? Black smoke usually means to much fuel, backfiring, can be to much air via vacuum leak. Don't think it would be a vacuum problem though. Have you checked your air filter? As that can cause over rich mixture and the problems you're facing.
door sm_vulkus
