Ga door naar hoofdinhoud
The first-generation XL-7 was Suzuki designed and had a body-on-frame construction. The North American version had a Suzuki-designed 2.5- or 2.7-liter V6 engine, on a rear-wheel drive-based platform with optional four-wheel drive. Beginning in 2003, European versions were also available with a 2.0-liter Peugeot turbodiesel engine producing 109 PS (80 kW).
5 Vragen Bekijk alle
Some doors open some don’t
I bought a new battery for my 2004 Suzuki xl 7 and now when I lock or unlock it, some doors unlock or some door lock but it never all either way. It never did it before the battery change. What could the problem be?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi,
To clarify, which battery are you talking about? The car battery or the car key fob battery.
When you say 'some' doors, which doors? Is it always the same door(s) or is it random which ones lock/unlock?
Try reprogramming the key fob to the car and see if this resolves the problem
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Have the alternator checked. Maybe it is only running from the new battery, which is not a good thing. When the car engine is running, power is generated by the alternator to run the car and replenish the car battery.
Score 1
Add an additional ground from the computer to the chassis and see if that fixes your problem.
Voeg je antwoord toe
lizards united zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 238
