Ga door naar hoofdinhoud
De HP Envy 17-J013CL is de 2012-versie van de Envy-serie van Hewlett Packard. 1600x900 resolutie op een 17,3-inch HD-scherm.
massive frame rate drop when playing regular games
so I have owned the envy-17 for just over 7 months now and i regularly game on it, currently its fortnite and GTA5. but recently I have found that trying to play either of these game at all is impossible due to large frame rate drop and large memory usage when I have had multiple hours of game play on both with no problem on this device. I have re-installed the graphics drivers a couple of times and completed virus and malicious scans that come up with nothing. I'm running out of ideas if someone could please help it would be greatly appreciated.
Is dit een goede vraag?
Score 2
1 Opmerking:
Hi,
Did anything change with the OS (or any other program updates) about the time the problem started?
Try disabling the A/V just to see if this may be causing the problem.
Have you checked Task Manager to see what programs may be running in the background that perhaps weren't there before or maybe have been updated?
door
Voeg een opmerking toe
1 Antwoord
What are the specs of your system? Hm. It is most likely RAM usage. Even though you explain its worked fine before that may of been before you have download different programs or other things became in use, therefor using more RAM in the background as playing your games. You can disable a lot of those programs in task manager, etc to try to fix this. Fastest and most likely the best solution is an upgrade in RAM.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kaelum van heek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 394
