Ga door naar hoofdinhoud
Handleidingen voor reparatie en ondersteuning van radios.
246 Vragen Bekijk alle
Alarm goes off cant turn off
We have a IKBC384S timer is at zero and at 12:00 AM the alarm goes off everyday. Not sure how to turn it off permanently. No instructions were included when purchased. Please help we just hit the power button and it stops
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
According to the User Guide:
Disabling the Timer:
To cancel the alarm after it has sounded, press the Power button.
To cancel the timer before the alarm has sounded, press the Timer button until the display reads 000 and the timer light is no longer lit.
Hopefully this may be of some help.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
this will only shut it off in the moment but it does it again 24 hours later.
door
Hi,
Does the Timer light go out?
Perhaps try a Power reset, i.e. Turn off the unit and remove the power (including the backup batteries if installed -see User guide), press the Power button for 20 seconds to remove any residual power from the unit, then reinstall the batteries (if applicable) and reconnect the power and switch on.
Check the status of the Timer
door
Voeg je antwoord toe
janensparky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 58
