Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
20 Vragen Bekijk alle
LCD backlight not working after front panel replacement.
Hi.
Tonight I replaced the front panel of my brothers iPad mini 2, ensuring to disconnect the battery before unplugging the LCD and Front panel, yet upon reassembly, the LCD backlight is no longer working. I am aware that unplugging the LCD with the battery connected often blows the backlight fuse, but I made sure to unplug the battery first. Could any of you advise what could have gone wrong?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
We have a backlight troubleshooting guide.
see if this is any use for you: iPhone Backlight Not Working
Was dit antwoord nuttig?
Any chance you damaged the LCD removing it?
1 Opmerking:
I doubt it, I shone a light into the LCD and there is an image, just no backlight
door
You may have already done this but unplug, clean and replug in all the connectors in. Happened to me before on iPhone, dust or something must've got into the connector. If that doesn't work I'm not sure what to suggest.
Voeg je antwoord toe
Daniel Bowden zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 67
