Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Change Back Cover and iPhone does not turn on
I changed all the componentes from the inside of the iphone to a new back cover but the iphone does not turn on, i checked all the components and all seem to be fine, any suggestion?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Can it connect to a PC? let us know what you have tried so we dont repeat what you have done
Was dit antwoord nuttig?
1 Opmerking:
No, it can't connect to PC
door
I would double check battery and power button contacts to make sure they are seated properly. Did you tear it down in a static free environment? With proper ground out?
1 Opmerking:
i think it is the battery, the glue ripped of the black cover from it, do you think it might be damaged?
door
Voeg je antwoord toe
eveduardo98 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 37
