Ga door naar hoofdinhoud
De Alcatel One Touch Idol 3 heeft een 5,5-inch display van 1080 x 1920 pixels, aangedreven door een 1,5 GHz processor. Uitgebracht in juni 2015. Modellen 6045Y, 6045K, 6045O, 6045I.
Why does phone gong instead of ring?
I have an Alcatel One Touch Idol 3. Occasionally, instead of ringing like it should (using the ringtone I selected as default) the phone just gongs slowly. It particularly happens when my son calls (I have no idea why). The problem is that the gonging sound is quite low in volume, and I almost always hear it too late to answer in time. Does anyone else have this problem, and if so, how can I fix it?
Is dit een goede vraag?
1 Opmerking:
Hi Joe,
Has the gonging ever happened when someone other than your son called?
door
Voeg een opmerking toe
2 Antwoorden
If the ring tone only makes that sound when your son calls and with no one else , then it sounds like you or your son set the ring tone to that sound. You can set different ring tones to each individual contact. All you have to do is go to your son's contact, click edit, scroll down to were it shows ringtone, and then change it or set it back to default.
Was dit antwoord nuttig?
I already checked that. The ringtone was set to default.
Voeg je antwoord toe
Joe Perrone zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 320
