Ga door naar hoofdinhoud
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
168 Vragen Bekijk alle
My nano screen is black
After connecting it to an external amp at work (or coincidentally) the nano doesn't respond to power button or usb line and stays off. It hasn't gotten wet. Help? thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
krista lie, try the Apple solution first
Will not turn on or screen remains dark
Connect iPod to power for at least ten minutes to ensure that the battery has enough charge to allow iPod to turn on.
If iPod does not turn on after ten minutes, try resetting the device while it is still connected to power. Reset the iPod by holding down the Sleep/Wake button and the Volume Down button for at least eight seconds or until you see the Apple logo appear.
If the Apple logo appears on the display, connect iPod to a computer and verify that it appears in iTunes and can play music. More information is on here Good Luck and let us know so we can help you further if need should be.
Was dit antwoord nuttig?
Score 5
6 opmerkingen:
The power+ down volume fix worked for me! Thank you!
door
you are welcome
door
Power and down worked for me too thank you xx
door
Me too, the apple solute worked for me but after a day the screen went back to what it was before and now the apple solution doesn't work :'c
door
ابي يشتغل
door
1 commentaar meer tonen
Voeg je antwoord toe
krista lie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 25,523
