Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de eerste generatie Apple iPad met 3G-mogelijkheden, beschikbaar met 16, 32 of 64 GB opslag. Uitgebracht in april 2010. Geïdentificeerd door modelnummer A1337.
Brightness stuck on maximum setting?
Apple iPad 3G 64GB (1st gen)
I replaced the metal casing on my iPad, which seemed to go well, but then I realized the brightness was stuck at max and can't be changed. Altering the brightness level in settings has no effect, whether or not auto-brightness is turned on. Everything else works fine. Please help me, what could be causing this issue and how to fix it? Thanks!
P.S. The brightness isn't just stuck at software max, it seems to be the maximum output supported by the hardware, slightly brighter than any brightness that can be set through the settings menu.
Update
I tried reseating all the cables including the ambient light sensor. I even bought a replacement ambient light sensor, that didn't help. The issue is the same whether or not auto-brightness is enabled, so I doubt the issue is related to the ambient light sensor.
I figure backlight limiting is tied to some kind of op-amp or an electronically-controlled variable resistor, I would expect if that component were damaged that the backlight would be always-off or always very dim. Give that I would think rather the issue may be related to a short, though I haven't seen one.
I could try replacing one of the other cables like the Display data cable, but I handled the cables well so I wouldn't expect them to be damaged. I could do a continuity test to verify the connection between each matching pin end.
To make it clear none of your suggestions worked (from your first response).
Is dit een goede vraag?
Score 3
4 opmerkingen
You seem like a bright person that has some understanding of electronics. This is not to your exact model of iPad it is for 16G wifi but it might help you find what you are looking for I am going to leave this document shared for 24 hours you may want to copy it for your reference:https://spreadsheets.google.com/ccc?key=...
A picture of the board with the LED driver marked:
http://i295.photobucket.com/albums/mm132...
door Deel
Thanks ABCellars, I'll try doing some testing to see if the white LED chip is connected and in working order.
door Deel
Great post, really appreciate the followthrough on what you've tried thus far. Did you ever find a solution?
door Deel
No nothing has worked so far. I damaged it further trying to fix the problem and now apps won't open any more.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Try reseating the Display data cable and the ambient light sensor. Those are the only cables that could affect the brightness settings. If that doesn't work, your last resort is a restore. I'm doubtful that it would be a software issue, it's more probable that a part was damaged (static?) during the back casing replacement.
Let me know if that works. If not, we'll move onto the next steps.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Robert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 3,106
