Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Phone wont turn on
I change display ( boken touch ) and used phone few days . After I take picture with camera the display turned white and swithed off phone ( battery was at 60% ) . Now it can not turn on . I tried with old display , but problem is not solved . Any suggestions ?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Could be in DFU mode. Is it recognised in iTunes?
Was dit antwoord nuttig?
2 opmerkingen:
How can i tried . Any link ?
door
Connect it to a computer that has iTunes installed
door
I had the same issue because of my connections of the lcd was not right. So Check that the cables fit properly.
1 Opmerking:
I tried with old display that has broken touch , but the problem is same .
door
Did you unplugg the battery every time you replaced the screen?
If not, I would check the lightning/image fuse
2 opmerkingen:
Yes , my first thing is unplugg battery
door
Test an hard reset - home button and power button the same time up to a minute and release if you see the Apple logo, if that dosent work then test unplug the battery and put in the charger and see if it goes to the Apple logo. If it does you got a bad battery
door
Voeg je antwoord toe
Damjan Jakobcic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 70
