Ga door naar hoofdinhoud
In 2000 werd een volledig nieuw model (codenaam XD) gelanceerd. De stationwagen werd geschrapt ten gunste van een vijfdeurs hatchback. Vanaf 2001 waren alle Amerikaanse modellen standaard voorzien van airbags voorin en zij-airbags voorin, airconditioning, elektrisch bedienbare sloten, elektrisch bedienbare ramen en stuurbekrachtiging.
Why is my car dying while driving?
I have a 2003 elantra and have recently had issues with it. Over the course of the past few months, it has stuttered and slowed to a stop while I was driving and then not started for a few minutes following the incident Without fail, if I wait 5-10 minutes and try to start my car again, it will turn on. Today, it escalated. After driving over 250 miles, my steering wheel locked and my car started to slow then die. A mechanic pulled over to help me and was not familiar with my model of car, but said it seemed to be an issue where the engine was not registering that fuel was in the car. (Jump start and starter fluid did not work). I'm supposed to drive another 300 miles tomorrow and I don't know if I should take the car in or hope for the best regarding the drive. Anyone know what it could be and how much it would cost (and how long it would take) to fix such a problem?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
b fleck could be many issues but since you said that "starter fluid" did not work it could be a bad camshaft sensor, a bad crankshaft position sensor or anything electrical. Best would be to have the OBD scanned and see if it throws any codes.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hi @oldturkey03 ,
Also of concern is why did the steering wheel "lock", "....my steering wheel locked....".
Possible faulty ignition key lock perhaps which may also affect the electrics
door
b fleck @jayeff is of course absolutely right. Check your ignition lock first! It could most certainly be the culprit.
door
Change the catzilla box to the so-called pollution tray
Voeg je antwoord toe
b fleck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 1,606
