Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Vragen Bekijk alle
How can I tell the difference between the iPad 2 models?
I'm about to order parts for an iPad 2 screen repair that has a dent on the side where the volume switches are. Even before getting the iPad dropped off, I'm assuming the volume/power flex is going to be damaged when it comes out.
My question is, without opening the tablet up how can I tell which iPad2 it is? The power-volume flex is different from the 2011 and 2012 re-release.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Oh, I just answered my own question. I never realized that there was a sub-number for the two iPad 2 models. Turns out the 2011 is an A1395 (EMC 2415), where the 2012 "iPad 2,4" is A1395 (EMC 2560). These EMC numbers can be found on the back of the device in the second row of small lettering.
Was dit antwoord nuttig?
3 opmerkingen:
Will the screens and digitizer inter chang
door
Will the screen and digitizer interchange between 2011 &2012 model
door
Hi Alfred - sorry for the delay... just saw your post. Yes the digitizer and LCD are interchangeable. The most functional difference between them is the on/off and volume ribbon cable is completely different.
door
Voeg je antwoord toe
Bill Shannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 420
