Ga door naar hoofdinhoud
Third generation Surface Pro tablet, released June 20, 2014.
123 Vragen Bekijk alle
How to change the backpanel?
Hi,
I bought a used Surface Pro 3 on Ebay.
On the Backpanel is a significant dent where (I think) the air grid is.
So I looked here to find a guide and the parts to change it, but saddly there is non.
Can some one possibly help me?
Regards
Jeff
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
It seems as though you have to completely dis-assemble the tablet to get to the back cover.
Here is a link to the ifixit Microsoft Surface Pro 3 Teardown guide, which may be of some help.
Here are some links to suppliers of the part.
It is not a recommendation to use either of them. It is shown to give an idea of the cost of the part. You may find other suppliers that suit you better. Just search for surface pro 3 housing back cover part to get results.
https://www.ebay.com/itm/OEM-MICROSOFT-S...
https://www.ebay.com/itm/Microsoft-Surfa...
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thanks for your answer. It was my fear that I would have to take it al apart. Don't know if it is worth the risk, with the screen being this easy to break...
door
Hi,
If it's not causing any problems, it may be better to live with it as it is than to risk damaging the screen (plus the additional cost).
Cheers.
door
I'm thinking the same thing. Have to wait and see if it works properly
door
Voeg je antwoord toe
jeffcampana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 51
