Hi fellow H3 owners,
this window problem just happened to me, It all started with doing a brake job, new calipers, rotors and . While I was working on the truck, I left the radio on and listened to my favorite music, for about a hour, . After finishing job I was ready to go for a test ride,.
The driver side window was stuck down, and all door locks would not work, all the other windows went up and down as they should, but still no drivers window, or door locks,! I checked all fuses, even #68 relay but still could not find problem, I drove 18 miles in 30 degree weather at nite, got home and was very confused with this truck.! The next day I took master control unit out of door disconnected all wires, cleaned pins etc, and put back together, also I took off positive and negative battery cables off battery, cleaned them , put them back on and tightened good, Well , I turned the key and everything worked,??? all good. windows worked, door locks worked, very happy with out come.
I went to dealer as this still did not make any sense to me, he told me that when the battery starts to get low in voltage the computers will sense some thing wrong and will start shutting down non-essential items in truck, drivers window and locks first, then other things like turn signals, driving lights, heater motor,!!! Man this truck has had me pulling my hair out, But still love my H3.
I hope this short story will help someone else who might have same trouble.
My girl friend has a H3 also, now I need to tackle her problem, no heater motor, no heat or AC. what next. I had this problem on mine so I know what it is, still a pain, and all computer related . Good luck all and good nite.
39 opmerkingen
I have the same problem. it occured about 6 months ago and I took the fuses out and they were all good, but the next day it started working. I have the problem again and so far haven't figured it out.
door chris
i have the same problem and it works some daysand dont work other days.
ds window dont work and pdl dont work
door colin lilly
Im having the same problem on my nissan altima 2007 , power windows don't work (all doors) power locks dont work (all doors) the blinkers dont work , hazard lights do work, i re placed the bcm relay and the power locks work and blinkers not the windows but after a day the relay burns
door Lando Cantu
what I have found on three different models is cracked solder joints on the window circuit boards.
door dpb5
Hi my door lock button does not work at all.i can't lock The doors by the button
door Celina A
34 commentaren meer tonen
