Ga door naar hoofdinhoud
Uitgebracht in juni 2017 als opvolger van de Surface Pro 4. Ook bekend als Microsoft Surface Pro 12,3". Modelnummer: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Is dit een goede vraag?
Score 1
2 opmerkingen
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 Scherm vervangen guide.
Just a thought.
door
Go for an iopener, otherwise it's too easy to damage the surface.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Afbeelding
Product
Heat Gun
$29.99
Was dit antwoord nuttig?
Score 3
I would use the iOpener or a heatmat.
Score 2
Voeg je antwoord toe
Daniel Mossman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 1,689
