Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
I had the same problem; blame flimsy construction. In my case the gear, which was made of the world's cheapest plastic, had partially worn JUST enough to make the thing skip. A friend of mine 3D printed me a new gear and after some careful disassembly, reassembly, and a couple dabs of hot glue, it worked again.
@ninjashadow3
If you heard gears moving, you need to check if the traverse mechanism is engaged properly / blocked / broke. take some pictures.
The Claw Item Replacement
door Augustine
door Steve
