Ga door naar hoofdinhoud
Uitgebracht in 1999, opvolger van de originele PowerMac G3, 300-450 MHz, 64 of 128 MB RAM, 6 of 12 GB HDD
Black Screen with Backtrace and Exceptions
Running OS X 10.4.11 on PowerMac G3. The system is constantly freezing and I have to restart. Often I get a black screen with a long list of backtrace and exceptions.
There is an extremely long stream of info on a black screen. Below I've listed one portion which differs from the rest:
Backtrace:
0x04DF358C
Kernel loadable modules in backtrace (with dependencies)
com.apple.driver.ndrv.ATY.Rage128.0x4df009c(1.0.2f 47)00x4def000
Exception state (sv=0x1D20C780)
PC=0x000AF354; MSR=000081030; DAR=0E02FD000; DSISR=0x42000000; LB=0x000AC134; RI=0x0000B9E0;XCP=0x0000001C (0x700 - Program)
Can anybody help me fix this?
Is dit een goede vraag?
Score -1
1 Opmerking
How much RAM do you have?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
what you're getting is called a kernel panic. start up from your system installation disk, go to the second screen pull down menu to utilities > disk utility and select your drive on the left. run the repair till it runs clear. if this fails, reinstall your system. how much ram do you have?
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I've only got 288 MB of memory. I've avoided investing too much into the system since it has this problem. If I could just get it to stop freezing up, I might have a chance to get to know and love it. Then I might consider upgrading it.
door
I don't have the original system disk that came with the system. I only have the OS X 10.4 installation disks.
door
You're running on the minimum amount of RAM. Use the 10.4 disk for repairing the drive.
door
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 19
Altijd: 686
