phone wont charge after being dropped
i dropped my phone and the sound doesn't work at all. Now the phone will not charge at all. Its not even registering the charger being attached
Is dit een goede vraag?
Annuleer
Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Rep: 1
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelSometimes after a drop, or after repeated drops, the logic board can be damaged, specifically the solder connections underneath some of the IC's. This can affect pretty much any IC and it can cause some unpredictable symptoms.
However, before getting into potential micro-soldering repairs, you need to eliminate the possibility that there is a problem at the modular level. Open up the device and insure that the battery is properly connected, as is the screen assembly. If you have access to another, preferably known-good battery or screen...or even a Lightning port flex, try those too.
If that doesn't solve the problem, then your charge circuit on the logic board is damaged and will require a micro-soldering repair.
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 40
Afgelopen 30 Dagen: 145
Altijd: 1,511
