Ga door naar hoofdinhoud
Een e-sigaret is een herbruikbaar alternatief voor traditioneel roken.
121 Vragen Bekijk alle
G Priv 1 wont turn on after update!
I was updating my G Priv 1 and while the update software was installing, the the program went unresponsive and I had to force close it. Now my G Priv won't turn on and my computer won't recognize the usb device. Is the mod totally bricked or is there a way for me to revive it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hey David,
Unfortunately, if the device is disconnected while updating firmware/software, it usually bricks the device, unless you would like to lean microsoldering. If you would, I would reccomend watching these videos, or these ones. Also, check out this guide. Sadly, I faced a similar problem with a $50,000 laser engraver. Luckily, it was only $800 dollars to replace some parts, but in your case, I don't know if it will be that easy (but much cheaper!).
Hope this helps,
-Tanner
Was dit antwoord nuttig?
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 713
