Ga door naar hoofdinhoud
Een volledig nieuwe Passat, gebaseerd op het Volkswagen Group B5-platform, werd in 1998 in Noord-Amerika gelanceerd.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
Is dit een goede vraag?
1 Opmerking:
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
2 Antwoorden
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Was dit antwoord nuttig?
1 Opmerking:
Air flow and throttle show a short circuit .wiring okay
door
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Voeg je antwoord toe
Stephen Ryan Bearden Madison E zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,727
