Fixing a Toy Pull String sound box
It's a Stieff brand Soft toy. And the pull string doesn't retract when it's pulled out.
I have opened it up, and it is all mechnical.
Inside there is:
- A spool for the pull string to wind onto
- A Music Box with a metal comb that is turned by a large spring (This spring is hidden from view)
- A spinner with small spring that turns when the string is retracting.
My question: Before I open up the box any further, can anyone tell me. Is it likely that the spring is the problem? Is it possible to repair a spring?
I can provide photos if that would help.
UPDATE:
Thanks for the great responses so far.
As you can see in the image below. I unscrewed the metal base from the plastic housing, and discovered that the spring encased in the grey box isn't able to be unscrewed open :(
As you can see in the green circle I've drawn, this grey case is held closed by a metal pin that is clearly not able to be disassembled. OR is it?
Would I need to open that up to get to the spring?
Any advice would be great. This toy is really lovely, and I'd love to preserve it.
Is dit een goede vraag?
3 opmerkingen
Brett Nathan post some images with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. It will allow us to see what you see. It does sound like the spring, It could be broken (unlikely) or just unhooked. We'll have to see more of this.
door oldturkey03
Thanks for help. I've added a picture.
door Brett Nathan
Brett Nathan yes you will have to remove the rest of it as well. Only thing to mindful of is the spring. Take lots of pictures while you take it apart.
Do a online search with term "Yunsheng music box" and there are a few videos that might help.
door oldturkey03
