Ga door naar hoofdinhoud
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
52 Vragen Bekijk alle
Worked for years then stopped. New batteries fully charged. Reset. No
Worked for years,then stopped. New batteries charged overnight. No good. Unplugged power, sound, removed batteries 30 min. to reset. Green light is on. Still no good. Now what?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Have you tried re-tuning the headset to listen if you can pick up the audio. The tuning wheel may have been shifted
If this doesn't work try changing the transmit channel (switch on bottom of base unit) and then re-tuning the headphones to see if it now works OK.
(click on image to enlarge for better viewing)
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
Good suggestion. Not successful. Slight hearing left side, BAD bass static right side.
door
Hi,
I know that you said that the green light is on, on the base unit but can you verify that there is actually audio available at the end of the cord coming from the audio source and not just a "loud" static or hum?
If you have another pair of 'standard' earphones plug them into the output of the audio source (if the plug is suitable that is). to prove that the audio is good leaving the source. Then if you have a speaker with the appropriate input connection plug the cord from the source into that to prove that the cord is OK.
Just trying to narrow down where the problem may be.
door
Good advise, I'll see if I can find an old pair of headphones to try. And/or a speaker. But again, there is some audio on the left side but it sure doesn't have much volume. Thanks
door
Unit lights are off plus headset doesn’t connect to the base
door
Voeg je antwoord toe
Hal Norling zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 24
Altijd: 1,142
