Ga door naar hoofdinhoud
First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Vragen Bekijk alle
My iPad will not fully restore itself? Itunes stops short.
My ipad syncs with itunes and itunes starts to restore it's software as it's should.But itunes gets almost to the end and stops. Can anyone help. thanks, chiob12002@yahoo.com
Is dit een goede vraag?
3 opmerkingen
When u say it stops; do u get any error messages, or does it just freeze?
door
it jest freezes jest befor completion.
door
Is ipad fully charged??
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Are you trying to restore an older firmware? Such as 4.2? You need to restore the current firmware on the iPad (And other 3rd Generation+) devices, (Apple's way of preventing downgrading) You can download it here and install it by shift-clicking "restore" in iTunes, and selecting the file. Also, if the file you downloaded has a ".zip" extension, do not extract it. Change it to ".ipsw" and iTunes will reconize it.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ why won't it open the zip?
door
I believe that the web browser changes the ".ipsw" extension to ".zip" automaticaly. iTunes will not open the .zip file, and extracting it will simply extract the contents of the firmware update file. You actually have to rename the file yourself, for iTunes to accept it.
door
Voeg je antwoord toe
chiob12002 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,784
