Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
went through washing machine
My 3GS went through the washing machine and is now not working. I did the whole rice, hair dryer thing and let it dry out. Though after I took it out of the washer it turned itself on so I'm not sure if the damage was permanent. That was about 3 weeks ago. When I plug it into my computer it will occasionally, but not always, show the Apple logo, then shows the connect to iTunes screen. iTunes will recognize my phone and says it needs to be restored. Unfortunately, everytime it does this I need to download the new iOS and by the time it's downloaded, it goes to the white screen and iTunes no longer recognizes it. Is there anything I can do for this?
Update
I cleaned the circuit board completely, then after I plugged it into my computer, the screen was white for just a few seconds then the battery screen came on, after that it dissapeared and the screen hasn't come on since. iTunes is recognizing my phone and when I click Restore, iTunes says preparing to restore, then I'll get a 1601 error.
Is dit een goede vraag?
Score 1
3 opmerkingen
recheck connector 1 is on properly/clean. let it dry and try again to see if the screen works
door
I've already done that several times, and like I said, the first time I plugged it in, the low battery screen came on then went away and the screen hasn't come on since, so it wasn't the connector.
door
Same happened to my Iphone 3. Did you manage to fix yours?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Chances are you did not rid the circuit boards of contaminates, residue and/or get them dry enough. Disassemble your phone. The gist of the procedures are here. Clean your printed circuit boards with rubbing alcohol and and a brush. Then submerge and agitated (move them around) them in alcohol to ensure that the ICs (Integrated Circuits)with BGAs (Ball Grid Arrays) have been flushed of contaminates. Wipe them with paper towels, changing them often, to ensure you are not smearing residues or contaminates to other places. Use a hair dryer ( on low to no heat) or a fan to expedite the drying process. With the use of the fore mentioned continue to let them sit over night to dry. Let them sit at least 24 hours with out the aide of air flow. Reassemble and give it a try. Good luck and have a wonderful day!
Was dit antwoord nuttig?
Score 4
1 Opmerking:
You don't need towels or driers, just let it sit and air dry.
door
Voeg je antwoord toe
Christopher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 2,325
