Ga door naar hoofdinhoud
Introduced as a two-door coupe in North America, the Dodge Avenger was built from 1994 to 2000 in a similar size and price class as the Dodge Daytona, which was discontinued in 1993.
1 Vragen Bekijk alle
What is makeing my left front wheel feel like it sways or might fall?
When i drive my Avenger pulls to the right alot but yesterday it seamed to have pulled hard to the left instead. So i adjusted pressure and put spare on till i got home. I put tire back on b4 driving and noticed alot of maybe bouncing in the wheel at the front left tire and alot of noise like loose brakes or something maybe but it felt like my tire was gona come off of the hub asslembly or something. I dont know what happened.
Also on my front left asslembly i only have 3 outa 5 lug bolts. 3 month old brakes pleanty of fluids thruout car. Ball joints look bad i believe..
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Michael Ferguson you seem to have a lot going on here. The number 1 concern I have is that you "only have 3 outa 5 lug bolts." this could potentially lead to losing your wheel. Get those replaced. It can also be the cause since it could cause your wheel to wobble. Again, replace those. Post some images of what you see regarding your ball joints etc. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
Bouncing etc (wheel hop) can be caused by plenty of things but do not forget to check your struts/shocks/springs etc.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michael Ferguson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 103
