Ga door naar hoofdinhoud
De Xbox 360 is de tweede spelcomputer die Microsoft maakte en werd uitgebracht op 22 november 2005.
Repairing firmware
Do we have anyone with experience in repairing firmware? I have disassembled many, replaced bad drives or ports, etc. I am looking for any Xbox 360 lessons-learned, knowledge, help hints, and any information on "bricking" and "unbricking".
Your assistance is greatly appreciated.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
1 Red Ring is a general error
2 Red Rings is overheating
3 Red Rings is hardware failure (ususally a bad joint between the GPU and Logic Board)
error codes are ususally not easy to fix, there are error code keys on the web, but there are tons of error codes.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Lazer setting off.YouTube it.easy fix.
door
Het nuttigste antwoord
ususally, xbox's don't get bricked, they have onboard firmware, and the firmware is not accessable externally, if you are trying to remove the NXE, it isn't possible, if you want to try, you may be able to trick the console into downgrading the firmware, by putting a firmware update file on the hard drive via special adaptor, but annother thing to know is that the xbox dvd drives are keyed to the motherboard that they shipped with, so if you get a new logic board, make sure that it comes with a DVD Drive
Score 3
1 Opmerking:
Thank you very much for the information...I wondered if they were keyed. Any info on red rings (1-3), error codes, and RROD. I am still learning. Thanks, Kelly
door
i found this really helpful.
http://www.llamma.com/xbox360/repair/Xbo...
Score 3
1 Opmerking:
Lots of good stuff here. +
door
These are the ones I use whenever I get to tinker with an XBox or just to keep mine alive. I do like xbins since it does have the proper software for remapping as well as firmware issues. Comes in handy....good luck.
Score 1
1 Opmerking:
Sorry forgot a few things :) http://www.xbins.org/
http://www.360-hq.com/xbox360/hardware/ that is what I meant to attach...
door
ok,my xbox360 starts screen freezes. scanable look. but with out hardrive it run disc fine. if idea.
Score 1
1 Opmerking:
HDD Problem, try replacing it.
door
Hi Anibal my Xbox 360 not how open work happen know not
Not work open each much time Xbox 360
1 Opmerking:
Not work Xbox 360 open not
door
Voeg je antwoord toe
aquabluekt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 6,619
