Ga door naar hoofdinhoud
Harley-Davidson Sportster-motorfietsen van 1986 tot heden.
Strange sound from my engine
Hi guys, i bought a sportster 883 r two months ago and i knew from the mecanic that the guy i bought it from, had a failure in the oil pump and he drove 15 miles, the mecanic said he changed the pump and one from piston head. But a tic tic sound is coming from the engine and the sound becomes higher when i drive long distance, anyone can help me what this sound may be???
Is dit een goede vraag?
3 opmerkingen:
I recently figured a new problem every 40 miles my rear spark plug is fouling is it related to the ticking sound??
door
Quite possible, is it oil fouling? If so your lifters may need adjusting, and if they are auto adjusting, you may need to replace either your chain/belt, slipper/tensioners. Does it blow a bit of smoke on start up, or when taking off from traffic lights. These are indications of valve stem seals and or valve adjustment.
door
Yes, it is blowing smoke on startup.
door
Voeg een opmerking toe
1 Antwoord
Tic ticking sounds are usually lifters. Or noisy valve train. I'd personally take it to another mechanic, don't tell him the story. See what that guys says it is.
Was dit antwoord nuttig?
1 Opmerking:
It could be anything really, as the engine may need a full rebuild.
door
Voeg je antwoord toe
Johnny Chebel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,259
