Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Restore Error 4013 iTunes Cable
i try restore came out error 4013 after the phone restart, no yet come out apple logo loading bar. I already try difference cable and difference computer is still same.
What is the problem ??
How to fix this problem??
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Contrary to the iPhone 6 series, error 4013 on the iPhone 6S is usually Baseband related.
You don't say if you have any micro-soldering experience so I'll put this out there for general reference. You will need to closely inspect the Baseband area of the logic board. There could be some loose coils or shorts/defective LDO's from the Baseband PMU. You will need to probe all of the outputs to insure everything is okay
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you bro
door
The issue is usually caused by the NAND chip.
Sometimes it only needs to be reprogrammed but sometimes the NAND chip can also be bad which would require replacing it as well.
There is an indepth video on how to do this here:
https://www.youtube.com/watch?v=c3Jr_0_f...
Edit: As said from the other answer, the issue is more likely related to baseband more than NAND.
Score 1
1 Opmerking:
Thanks bro..
door
Voeg je antwoord toe
Alvin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,068
