Ga door naar hoofdinhoud
A model in the Q400A series by Asus. This model features a 14" display and contains a quad-core i7 processor, 8GB of RAM, and a 750GB hard drive.
2 Vragen Bekijk alle
Will not charge. Bought a new battery. Bought a new charger. Will not
The previous battery would not hold a charge. Laptop would work when plugged in. Then stopped. Ordered a new battery and a new charger. The new battery worked until the charge emptied out. The charger will not charge the battery. What do I do now or where do I go to get it fixed?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @gye7293 ,
Does the laptop indicate that the battery is charging when you just connect the charger to the laptop?
If not, as it doesn't start with the charger connected, then you may have a faulty DC-In jack.
It may be faulty or it may have become disconnected from the motherboard.
Here is a video that shows how to access the DC-In jack.
Here is a link to just one supplier of the replacement part.
It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are others online that may suit you better. Just search for Asus Q400A DC-In jack part to get results.
You will need soldering expertise and tools to effect the removal (if necessary) and replacement of the part.
If this seems too daunting, contact a reputable, professional laptop repair service and ask for a quote to repair the laptop. You already know the cost of the part. ;-)
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Lora zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 273
