Ga door naar hoofdinhoud
Reparatie-informatie voor de Samsung Xpress SL-C410W/XAA kleurenprinter. Voor het eerst beschikbaar op Amazon in juli 2013. Modelnummer: C410W.
Imaging Drum reset?
I have the xpress C410W laser printer. I have a model that does not have the resistor clipped into the front of drum unit. I have a plug in board located under cover on front door. I want to reset the drum as it’s in perfect condition, I purchased resistors but have no where to put them. This board that connects to the prongs that make contact with toner cartridges does this contain the resistor for the drum too? And what can I do to reset this drum?
Is dit een goede vraag?
Score 3
1 Opmerking
What size resistor did you use, my color code shows 1 Ohm. someone thought it was 56 Ohm. Thanks Dennis
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
My imaging unit did not have a resistor either so I twisted the resistor onto the two lowest contacts on the door (where the resister unit should touch if there) and powered the unit for a few minutes and the light went out. I then pulled off the restistor. I have the original imaging unit and mine is a C410W.
That worked for me.
PS. If at first it does not work then leave the resistor on and wait for all the printer to do its fits and stops and the light should go green. Then turn it off and pull off the resistor
Was dit antwoord nuttig?
Score 2
Resistor is located behind two square contacts on the front side of imaging unit (below contacts for every toner).
Look at photos in this review article:
https://www.digitaltrends.com/printer-re...
image:
https://icdn9.digitaltrends.com/image/sa...
Hope it helps someone.
Everybody try to enlist yourself for the HSRP so you won't get fined. In the event that you are from outside Delhi yet live in Delhi, '''WB HSRP Book Online''' Visit your Vehicle enrollment State site for enlistment or contact your closest approved vendors.
Voeg je antwoord toe
Ginger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 8,532
