Ga door naar hoofdinhoud
Model A1046 or A1095 / 1280x854 screen resolution
118 Vragen Bekijk alle
Vraag afgerond
How much ram could be added to this Mac
im in argentina,desinformation runs rampant around here,would like to know specific types of ram to install in my powerbook g4
what kind of ddr ram or socket,or where can i see this info,thank you,great help
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I have the same model Powerbook. It takes PC2700 DDR (333 MHz) RAM, with a limit of 1 GB per RAM slot. There are 2 RAM slots available. However, be forewarned that one RAM slot commonly fails in this model, as what happened to mine. Therefore I can use only 1 GB in my Powerbook.
Was dit antwoord nuttig?
thank you bernie,just what i needed,the pc2700 ddr kind,but my powerbook its currently running on 2 half gb chips so that means that both slots are working,cross my fingers that will work when upgrade done!!sorry the writing,thanks again,will post the results.-
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 498
