Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Can of air alternative?
Just recently, I purchased an electric air blower for my pc and other similarly scaled electronics. However, I’ve found myself needing compressed air, but at a smaller and more concentrated size for blowing dust out of my phones. Does anyone know if there is a small electrical air blower I can purchase? I don’t want to have to keep buying cans of air.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
The best you can do is this True Power Rechargeable Sprayer. I still use can'ed air as this doesn't last as long.
I use it to hold cleaners like distilled water and isopropyl alcohol to clean things.
Keep in mind many of these compressors tend to have oil in the air which you don't want when cleaning optics.
Was dit antwoord nuttig?
Score 2
@masterchef
Have you considered going the opposite direction? Instead of blowing the air out, use a high powered vacuum? A brush attachment on a vacuum works very well.
Score 1
1 Opmerking:
You do need to be careful as some are glorified Van de Graaff generators. The piston design can create quite a large charge which can zap your electronics.
door
I use a DataVac Electronic Duster. It has 5 different nozzles so you can pick just what you want.
Metro Datavac ESD Safe Electric Duster - Model ED-500ESD - computer and equipment duster
Score 1
Voeg je antwoord toe
Erick Villa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 261
