Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
My screen is black after replacement
I bought a screen for my SE and after i was done replacing and switching the screen the whole screen is black but I can still touch and turn it off manually with slide to power off I just can't see it or anything else on the screen.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
if you didnt disconnect the battery when replacing it chances are you have blown the backlight filter
Was dit antwoord nuttig?
Score 2
8 opmerkingen:
And if i did what can i do about that
door
you need to take it to someone that does that kind of repair, it could also be a faulty backlight on the lcd, if you still have the old screen and backlight was working on it, then connect it to see if backlight is working
door
Where is the Blacklight located?
door
the backlight is on the lcd, the filter is on the logic board
door
im having the same problem, did you find a soloution in the end?
door
3 commentaren meer tonen
When the repair was carried out, did you disconnect the battery. If you did not, it is likely you have fried the device. I would try fitting a new test screen, and if that does not fix the issue then it is a board problem.
1 Opmerking:
yes the battery was connected
i’ve tried new and old screen and neither work, i can hear the notifactions but just no display
door
Voeg je antwoord toe
Dakarai Riverson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 85
