Ga door naar hoofdinhoud
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 Vragen Bekijk alle
Will not turn on, Just vibrates when on charge and has new battery
Hey guys i have a samsung j1 i left it at home one night and when i came home it was flat i tried to turn it on it didnt turn on so i put it on charge and it just vibrates every 5-10 seconds continuously and i have replaced the battery and it still just vibrates on charge and whrn you try turn it on it vibrates to let you know it has switched on but then nothing happens and i need pictures and data off the phone
Is dit een goede vraag?
Score 6
6 opmerkingen:
@telfz0r Is it still being recognized by your computer when plugged in? this sounds like a display issue since that is what could make it vibrate.
door
HEY i have the exact same problem no visuals on the screen just the rythmic buzz every 5 seconds letting you know that your lifes a failure and nothing will ever be right again. If you solve this problem please let me know :)
door
Anybody find a fix ?
door
fml :( buzz buzz
door
mines is doing the same thing
door
1 commentaar meer tonen
Voeg een opmerking toe
4 Antwoorden
Option one: Try a new charger.
Option 2: Go to a service center and replace the charging panel
Was dit antwoord nuttig?
3 opmerkingen:
Sometimes when a charger is in the same position for a while, this happens. It will only charge in a specific position, which explains the continuous vibration. It is simply charging in one position, then not charging when you move it even slightly. You need a new charger.
door
No its not the charger I have tried 5-10 different combinations of power connections and USB cords
door
Mmm...I'll keep that in mind.
door
try replacing the screen
Hi,
This might be because of 2 reasons
  1. You may be decided to turn on a phone whoch was switched off for like months or weeks.
  2. If you have new battery issues or battery replacements
So you may try charging using a high power adapter and the original working cable. Along with this try cleaning your phone charging port using toothbrush (with petrol drops if required)
What if the phone had got in contact with water and then it starts vibrating without turning on or showing that it's charging after 3-4 days of drying off?
1 Opmerking:
It's a Samsung J7 pro
door
Voeg je antwoord toe
Jake Walters zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 211
Altijd: 18,378
