Why doesn’t my TV get a signal from my Nintendo?
When I turn my Nintendo on, the TV says “no signal”. The Nintendo is on (the red light is on), I’ve set the TV to COMP/AV and I’ve plugged the red and white cables into the red and white plugs but have no yellow plug for the yellow cable.. I tried plugging it in all the other colored plugs and it still hasn’t worked (that’s what I do with my DVD player, which works).
My TV is HD.. is it possible that it is too new and isn’t compatible with the Nintendo?
I also had to purchase a new AC adapter.. is it possible that it’s not strong enough?
Thanks in advance!
Is dit een goede vraag?
2 opmerkingen
I have the same issue too, I know my TV isn’t broken because it accepts SD signals. What happens is when I turn it on, the “no signal” still shows on the TV. I even tried using RF and known working AV cables but still nothing on the TV nor sound
door Ricardo
You need to tune it, needless to say but make sure its on the analog band and not the digital one (most of tvs has a digital freeview tuner inside and the signal is different. The old one goes in plain radio, normally itd be UHF band)
door juanca iturriaga
