How to repair etch a sketch
This is an etch a sketch from the 80's. White knobs turn, but there is no drawing. Can I fix it?
Is dit een goede vraag?
An Etch-A-Sketch is a simple machine where the knobs end up moving a string from side to side and another from top to bottom. If the strings stretch or for any reason slip, you will get the behavior that you describe. Other than opening up the unit and replacing the string, there is not much that can be done.
Dan
Was dit antwoord nuttig?
This seems like the same problem: Can I fix dead areas on the screen, where lines don't appear?
How do I fix a etch a sketch if it has a see through screen
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 157
Altijd: 14,603
6 opmerkingen
Did any body find any answer to this problem?
door lorriepwr
What if it’s leaking aluminum?
door lorriepwr
I've heard of problems like this a lot so this could be a common issue with etch a sketches
door Percy WONG
Mine just will not draw idk what is wrong with it if some one can pls help me that would be nice it is something I use to help with stress and paying attention and dont really wanna buy a new one if you can help me that would be amazing
door Sarah Dearry
Mine stopped working the day I got it the vertical line knob stopped working -_-
door London Miller
1 commentaar meer tonen
