Ga door naar hoofdinhoud
A 10 speed mixer made by KitchenAid in 2006.
27 Vragen Bekijk alle
Kitchen Aid Professional 600 stand Mixer knocking
I’ve looked at some online info and we pulled the mixer apart. It is knocking but still turns. The sound is coming from the gears. I am assuming it is the worm gear but everything looks ok. Do I replace the whole worm gear or could it just be a bushing?!? Could it be something else?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @rnco ,
How much "play" is in the worm gear or in the drive gear? (vertical or horizontal movement - normally with gears it should be minimal as they should turn with virtually no movement on their rotational axis. The gear shafts should be held in position)
If either is loose that's where the knocking sound may come from
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rachael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,204
