Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Vragen Bekijk alle
New home button installed but not working
I had a customer come to me with an iPad Mini 3 with a cracked digitizer and snapped LCD. The home button flex cable was also snagged in the damage and needed to be replaced.
I reused the spacer, gasket and bracket when installing the new home button. However, after installing the LCD and digitizer, the home button isn't responding. I've taken it back apart and reseated the home button flex cable but haven't had a chance to test it yet.
Is there a contact on the home button bracket that needs to be lined up with the home button on order for it to work?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hello!
If it does not work, it is likely that the flex is damaged. The fingerprint will never work, but the home function should do it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Bill Shannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 74
