Ga door naar hoofdinhoud
Quadcopter met vooraf geïnstalleerde cameragimbal, 4K-videocamera en draadloze videotransmissie.
Why doesn't my drone start?
i go through the start up process, calibrate the compass, and when I pull back on the controller levers to start the motors, blinking green lights on the drone go to red and it does not start. I have repeated the process and sometimes it does start and fly as it's supposed to but most of the time it does not.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
well I would start with what I know, batteries are full in both units ?....I think you've flown this combo before, did anything happen since your last flight, maybe a "light" crash , radio (controller) get "bumped" off the kitchen table? it doesn't take much for a pcb to break a connection just to ruin your day. Without turning screws and opening anything up (not recommended) their are only a couple things it could be, I would start with the batteries
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I have 3 batteries and I have the same issue with all 3 fully charged. No crashes or bumps. It did set up unused for about a year but it was fine for the first 5 or 6 flights before this issue started. I thought maybe it was the Wifi extender but I'm still experiencing the same problem after changing it.
door
Voeg je antwoord toe
Alvin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 605
