Ga door naar hoofdinhoud
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
13 Vragen Bekijk alle
SW5-012 motherboard getting hot when I connect the battery
motherboard for SW5-012
I cannot power on my SW5-012 because my SW5-012 motherboard gets hot ...
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@himo if it only gets hot on battery I'd start off with a replacement of the battery. Re-evaluate after that and if it continues you are most likely having a shortcircuit on the boards charging circuit. For further help we would need to have the exact model number of your motherboard, not your computer. It is possible that schematics are available for further troubleshooting.
Was dit antwoord nuttig?
Score 2
I am having problem with my switch 10. It does not turn on but has an orange light on when the charger is plugged in. Also the motherboard gets hot. I opened the chasis and saw two wires were disconnected. Can anyone suggest a way such that the wires can be connected
Voeg je antwoord toe
Abraham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 470
