Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 Searching / No Service
Hey, My 2 year Old IPhone 6 cannot seem to get any service I have tried the drop method which does work But only for a small period of time .The phone recognises when the sim is in or out of the phone ,I cannot get the imei number when I call *#06# But can get it in settings. The phone previously had problems with The Touch ID and Charge IC On the motherboard Randomly Breaking and not working but I got them repaired.If anyone has any idea what this is Please let me know ,
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
This is an issue with the logic board relating to the baseband chip area. You will need to take it to a micro-solder to fix.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
How does this Chip just break by itself for so many people and why does it sometimes work when dropped?
door
This occurs because most of the major chips on the logic board on iPhones are BGA mounted (ball grid array mounted) meaning they basically sit on an array of solder balls. Also the design of the phone is pretty thin.
This is vulnerable to bad solder joints that break with lead free solder and as you know the iPhone 6 frames bend too easily which can make this issue occur easily.
door
For the OP...additionally, there are two copper traces underneath the Baseband IC that tend to crack from all of the drops, impacts, flexing and twisting. These have to be solidified.
door
Place the non-original chip (ie, a chip other than the bracket on which the device is locked) and connect the device to iTunes through a USB connector. When the device is detected by iTunes, back up and select Restore. (Try restoring without holding Shift / Option, or place the iPhone in DFU mode to do this.) After the restoration process, you will have two options: Restore from a backup and Setup iPhone as a new phone. Choose the second option. After selecting the second option, you must skip the activation steps. After the completion of the activation steps must appear (if nothing happens, repeat the steps)
Also, There is something thing loose inside the phone if that has to do with anything?
Voeg je antwoord toe
Aaron Clarke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 4,149
